How to change cartridge of HP J4580
How can I change the cartridge of HP J4580
Is dit een goede vraag?
Here is a link on replacing cartridges in your HP.
Was dit antwoord nuttig?
Solution of HP printer cartridge Issues
1. In Windows . Select Start.
2. Select Printers & Faxes (or open the Control Panel and select the Printers & Faxes folder)
3. Select your HP printer.
4. Click FILE on the top right corner and select Printing Preferences from the pull down menu.
5. Select Advanced Options Tab.
6. Click on More Options.
7. Select one of the following two options.
a. Never Display the print status
b. Display the printing status minimized in task bar.
8. Press OK, Press OK, and close windows.
Steps to replace the cartridge of HP OFFICEJET J4580
Found these info from WorkAroundTC
That's it :)
At first you need to open the door of the cartridge. After that you need to remove the empty one (that one you want to be removed). Furthermore, remove the new cartridge and remove the plastic from it. In the end, place it in the empty slow and press until you notice a sound similar to short click. Finally, close the door and you are done. In case you are getting any errors you can run HP Printer Resetter and reset the printer back to its defaults. After that, all errors should be eliminated.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 2,080
