Ga door naar hoofdinhoud
Repair guides for Android cell phones manufactured by ALCATEL.
991 Vragen Bekijk alle
How come my txt messaging won't send text messages?
How come my text messaging won't work? I did a hard reset on my phone and now my text messaging won't work it has always worked before never have had a problem with it. It's also not letting me text out on hangouts or messenger which I also tried in place of my text messaging. I can send pictures out but not text messages. And yes I can receive text messages I just can't send them out
Is dit een goede vraag?
Score 5
9 opmerkingen
Hi,
Has it worked OK before? Can you receive SMS messages OK?
door
Yes I can receive text messages I just can't send them out.
door
Can't receive texts and it takes so long for a text to send
door
Can't receive messages but can send messages
door
I do receive messages but can't send out
door
4 commentaren meer tonen
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Hi,
You need to ensure that the SMS Service Centre setting is set for the service provider that you are using. Each service provider has a different setting (usually a phone numbber or a code). Go to your service provider's website and search for 'SMS Service Centre setting'.
Here is a link that shows how to get to the setting. Even though it is for a Pixi it should still be relevant to your phone. If your carrier is not listed, just click on I can't find my operator to carry on with the page. Hopefully it will still help you.
https://www.helpforsmartphone.com/public...
To get MMS (texts with pictures or videos) to work (as it is different to SMS) ensure that Data Connected is on. Again not sure but it should be somewhere in Home > Settings > Wireless & Networks > more > Mobile Networks > Data Connection.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Thank u for your hel i try it straIght aWaY
door
Hi @ Steve Cline,
Can you receive calls OK?
If so, try starting the phone in safe mode (should be the same method for your model if it is an Alcatel phone - you didn’t say the model number) and see if you can receive texts OK.
If you can, then a downloaded app is the cause of the problem. The trick is to find out which one. You’ll need to uninstall each downloaded app, one by one, and test the phone in normal mode, between each uninstall, to see if the texts work OK. When it does then the last downloaded app uninstalled was the problem. Perhaps start with the ones that may have been installed or updated around the time that you noticed the problem happening.
If it also fails to work in safe mode, I suggest that you contact your mobile phone service provider about the problem as it may be at their end and not with your phone.
Score 2
I had the same problem, I was receiving texts but sent ones were stored in Outbox. It turned out I had deleted the last 2 digits of Service centre number by mistake
Score 1
3 opmerkingen:
How do I check the service centre number to see if it's correct?
door
Hi @ rchoner111,
Just Google "SMS centre number (insert your phone service provider's name)" to find out the number and then check if that is what is in the phone.
door
Hi
Sometimes ago I clicked on never send messages to me options from a short code and since then I don't receive messages from short codes and I can't send either, please, how do I undo it and get my phone to send and receive messages from short codes
door
It was a long time but had accidentally deleted the last number by mistake too. I tried all the numbers 1-9 and then it worked
Voeg je antwoord toe
yippitydoodaw.sd zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 46
Altijd: 66,897
