Ga door naar hoofdinhoud
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Vragen Bekijk alle
Why is there a blinking question mark folder appears
Hello.
After I turned my macpro on, it appears a blinking question mark folder.
It seems like there's sound came out from the hard drive. Eg" kit-crack kit crack"
It happens after I spill my water and it flows into my macbook pro through the touch pad. It was alright (nothing has damaged) after I turned it on after 4 days. But the next day after I turned it on, it became this.
May I know where and what's the problem and how can I fix this?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Ummm, if the MacBook is acting up like this, then something definitely happened.
A blinking ? is a sign of NO BOOT DEVICE. That's no Hard Drive is available to boot from.
Sounds like that water did get in there and it got to the connector for the hard drive, which is very close to the trackpad underneath.
I would get that opened up and looked at. Leaving it for 4 days may have done it in, whereas if you had gotten in there and dried it out with a heat gun or hair dryer you may have been able to save it.
Good luck, this kind of sucks and I hope you get it running again.
Mike
Was dit antwoord nuttig?
You could try installing a new OS it might fixit but thats usually a sign of a Hard Drive Failure but because of the water damage a hard drive replacement still might not work I would sagest a water cleaning as soon as possible to prevent corrosion on other parts of the computer and it might even save your computer.
Voeg je antwoord toe
Alanis CC zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 1,328
