Ga door naar hoofdinhoud
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
214 Vragen Bekijk alle
not responding screen black screen
hello,
i have bought new screen with the digitizer .. i had the iPad ready before the screen arrived it was working perfectly all i had to do is connect the cable for the new screen on the iPad and I'm done! what i didn't see coming is that the screen did not respond! its black i thought something must be not right with the screen so i plugged the old screen to check and it tuned out to work perfectly!!! when i tried with the new screen it still black and after a while the old screen didn't respond as well the new one either black or with lines .
what can i do ? what to replace etc!
Update (01/19/2017)
this is the screen
Is dit een goede vraag?
1 Opmerking
are you replacing the digitizer or the lcd? did you disconnect the battery prior to replacing?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
this lcd display in pic is shot. you will have to replace it with more care as the lcd panel is extremely fragile
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
the problem is i bought it from the website and it came to me in the pic you see
door
hi Maryam then this has likely to have happened in the post due to the fragility of the LCD crystals in the display. it is not uncommon for us repairers to lift a lcd display working and replace it finding it damaged even with the up most care being used. the replacement will solve your issue thought and isolate the battery prior to replacing the display
door
Voeg je antwoord toe
maryam zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 141
