Problems with nvram -c command
hello, I have a big problem.
I wrote in terminal "nvram -c" because I wanted to fix the fan velocity of my Mac Mini 3.1 (early 2009).
Now the problem is the light in front of the Mac Mini does´t work and also the fan works from the beginning.
Before I wrote in terminal I could configure the fan speed with fan control app, but now this program can't detect that exists a fan.
What can I do? is it possible to reverse the situation? if I change the battery inside the mac mini is possible to fix it?
Is dit een goede vraag?
1 Opmerking:
Have you tried booting up in Safe Mode?
What is your OS version and what is the app and version you where using here to control the fan?
door Deel
Voeg een opmerking toe
