Ga door naar hoofdinhoud
Canon's third iteration of their long-lens point-and-shoot camera design. Originally released in February of 2006.
20 Vragen Bekijk alle
My camera takes black pictures. How do I fix it?
I have a Powershot S3 IS. Its has been a very good camera for me.
Yesterday I was talking some pictures in a museum and the camera suddenly starting taking black pictures. In all conditions and settings camera is taking black pictures. I am not able to see the actual scene that I want to capture. Camera shows it black. But capturing pictures is working normal and capturing black pictures. I can see all the graphics and setting numbers on LCD and View finder. I can also see previously captured pictures and videos without any problem.
Please guide me how can I fix this problem.
Update
Yes by blinking I mean moving parts. Whenever I clicked a pictures there use to be a blink in the lens. I don't see that blink since the camera has stopped working.
Is dit een goede vraag?
Score 8
16 opmerkingen
I have this exact same problem.
The shutter iris doesn't open on power up on my S3. I held the telescoping lens in place on power up (forcing it to stay down). This opened it a couple times, but on power down and up, same problem.
Does anyone have steps to opening the lens to fix it?
door
Hi! I have the same problem with my Nikon P900. It was fine yesterday, but when I opened it again, all I see is black, when I take pictures, Its black.
Please help me fix this.
Thanks!!!
door
I have the same problem .. Plz help me
â—»
door
Take the lense cap off
door
Hi, are you here Camera Repair, or anyone?
I have a similar problem, my camera only takes black pictures and the screen is black and flickers with horizontal lines when i turn it on. The shutter opens, I did the check you suggested above and could see the shutter blinking when i took a picture, so it isn't that. Could it be the sensor, as you suggested regarding the initial question on this post? Do you know how i could check, and how to fix it??
Thank you so much, it would be great to hear from somebody. Thank you!
Dane
door
11 commentaren meer tonen
Voeg een opmerking toe
8 Antwoorden
Gekozen oplossing
Sounds like your sensor stopped working or the shutter stopped working....
Do you see anything via live view?
Assuming thats what you meant when you said "not able to see the actual scene that I want to capture" the it could be the sensor or the shutter, assuming there is one. Do you see the aperture blades when you take a picture?
Was dit antwoord nuttig?
Score 8
3 opmerkingen:
Set the camera to manual and overexpose by as much as possible and set the F stop to like Æ’/8 or something high so you can actually see the aperture blades if/when they engage
door
There is no blinking in the camera lens when I try to click a picture. That is really strange. Previously when the camera was working, out of curiosity I had observed a blink in the lens when I try to click a picture.
Please guide me what to do next.
door
A blink could mean shutter or aperture actually... what kind of blink? do you see moving parts?
door
Know this is an old post, but this is a very common problem for the Canon S2 and S3 IS series cameras, and there are likely others reading this with the same problem. But happily, it's easily fixed without even putting a screwdriver to the camera. A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and simple troubleshooting steps to correct the problem.
Score 5
1 Opmerking:
Wonderful , Thanks
door
Sounds like the shutter is stuck closed. I've seen this several times on the S2 IS. Usually there is an oily substance on the shutter blades.
Score 2
Hi
We are repairing this model.
The camera lens apart and clean and the iris blades
Also cleaning the shutter. Since the iris blades from sticking together through a substance, the dark picture. After assembling the camera works properly again.
Score 2
I recently replaced the CCD sensor on my old S1 IS and now it works great. I was getting the black picture problem. Overall, replacing the CCD was a medium difficulty repair, with the hardest part removing the glue that was placed around the screws holding in the CCD and finding the correct bit (T4) to remove those screws. Overall, it took me about 1-2 hours to repair. I found the replacement CCD chip on ebay for $10.
Score 1
I am facing the same problem with my canon 1500d what can be done and how much will it cost for the repairs
Having the same problem, but with the 2008 FS100 Camcorder. I don't think it's a shutter issue because sometimes it randomly fixes back to normal after some glitching going on. I'm thinking it's something to do in between the lens and the display, but I don't know what. Any ideas?
This just happened to me with the same Canon S3! I havent turned it on in many years and kept all my cameras in a rather mouldy sticky mancave shed. It wasnt stored in a totally sealed case and the handle is now very sticky! My S2 seems to work fine but it was kept in a totally sealed case. Other cameras not sealed totally seem to have crap in the lenses now too lol
Voeg je antwoord toe
Rinkal Shah zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 31
Afgelopen 30 dagen: 124
Altijd: 126,823
