RAM Upgrade 2133 MHz now having problems
Hi,
I have a MacBook Pro (13-inch, Mid 2012)
I had upgraded the RAM modules of my MacBook Pro to 2133 MHz Using Kingston's HyperX Impact RAM, I was using these in my system for more then 2 years, a few days back, I had some GPU issues so I removed my HyperX RAM modules and Reinstalled the original Apple RAM and gave it to Apple to repair.
Apple has now replaced the Logic Board, I then put back the HyperX RAM back in my system and it only shows me a solid power light when I turn on my Mac. It doesn't boot up or make any chime noise or anything, I don't know why this is happening,
The HyperX RAM were working fine for so long but after the logic board change out there giving me issues. I even tried my RAM modules in on someone else computer and the RAM works just fine. It's just not working in my computer!
What should I do?
Is dit een goede vraag?
3 opmerkingen
Is this the RAM you used? Kingston HyperX Impact RAM
Here's Apples RAM guide: MacBook Pro: How to remove or install memory
door Dan
door Dan
Same goes to mine... GPU glitches after few minutes, put back the 1600 MHz RAM its works fine. I used to put in 1866 MHz with no problem, no more...
door khaidir77
