Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
battery changed, phone switches off randomly
i've changed my battery, and now it sometimes switches on and stays on, and sometimes randomly powers down, or, sometimes when i switch it on it keeps cycling to the apple screen over and over. the new battery was 57% and then charged up to 100% really fast.
i'm also almost 100% sure about the screws, i stuck them to tape in the right configuration and didn't tighten them too much.
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Hi,
I would suggest trying another battery replacement, depending where you got it from, it could be a cheap, or faulty battery, try get a replacement. :-)
Was dit antwoord nuttig?
Score 3
Het nuttigste antwoord
Probably a faulty replacement battery
Score 3
Thelia from what you have said I think you have dislodged the gas gauge filter at the back of the battery connector. If you have tried the original battery and the symptoms are the same then a local repairer will be able to fix this quite easy. It is basically a false reading between the board and battery. I am sure you will find gas gauge posts on here for you to confirm this
Score 1
Voeg je antwoord toe
thelia zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 74
