Why cannot update my system?
Whwn im trying to update my apps it show error 504
Is dit een goede vraag?
Error 504 means the app couldn't be downloaded due to an erorr, or the gateway timed out. So if it is a HTTP error, it means the server in between you and Google timed out hence the problem!
I am not sure if you are on Wi-Fi or a cellular network, but you can try this anyway I guess! Go to Settings and find Airplane mode, you may be able to get to this by sliding in from the top of your screen as well. Turn Airplane mode on and wait a ten seconds or so, and then turn it back off. Check your Wi-Fi or cellular connection and wait for it to reconnect. Make sure you are using a good internet connection as well.
You should also check your storage space and ensure you have enough storage!
Try updating the application again. If you still get the error, go to the next step!
This is the last method and it involves a little bit more.
Go back into Google Play and try to update the apps.
Hopefully this works for you!
Was dit antwoord nuttig?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 24
Altijd: 169
