Ga door naar hoofdinhoud
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
LCD Screen Distorted. Possible bad Connector.
Hi there, I'm having some trouble with my iPhone SE screen. I ordered a replacement LCD and Digitizer and after replacing it I had to remove it again due to digitizer issues, I ended up breaking the screen and ordering another one. However, when I got my second screen after plugging it in I noticed the LCD had a fuzzy display with a line down the middle. I tried the screen in my brother's 5S and it worked perfectly, so I'm thinking it's either the logic board or the connector itsself. Has anyone encountered this problem?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
More than likely a copy lcd, the iPhone SE doesn't work well with copy lcds, but the 5S will work with them fine.
You'll need an original quality LCD for it to work correctly. :-)
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
Thank you very much for your response! It was a cheaper website so this definitely sounds plausible! I'll give it a try with a better quality screen.
door
Not a problem! :-)
door
Voeg je antwoord toe
Tyler McEwan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 530
