Ga door naar hoofdinhoud
The Motorola Razr V3c is a CDMA2000 version of the Razr.
8 Vragen Bekijk alle
#7 on key pad is very intermittent (3%)
#7 on keypad hardly ever connects. Verizon sprayed a cleaning product on the external keys. The key "clicks" but rarely makes contact. I like the phone. Repair shops quote $40 to replace the entire keypad.
Thanks for any input.
Joe
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
maybe try taking the plastic frontage off the keyboard and layering a tiny bit of tinfoil underneath it, so the contact has something to touch?
I've done this with other types of buttons before, I believe it might work for you. it's worth a shot, anyway.
hope that helps!
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thank you!. Now I try then I tell you
door
I would use the guide to remove the keypad and would clean the contacts under the adhesive that holds the half button - i never yould use something that could shorten anything inside a phone
door
Voeg je antwoord toe
jbass43314 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 14
Altijd: 1,486
