Ga door naar hoofdinhoud
Handleidingen voor de Wi-Fi-versie van de iPad Mini 4—model A1538. De iPad Mini 4 werd aangekondigd op 9 september 2015 en is de opvolger van de iPad Mini 3.
Touch ID not working after screen replacement
So I attempted to replace a broken screen on the iPad mini 4. I successfully replaced the screen and home button but then realized the Touch ID isn't working. Of course, after the fact, I read how this can happen. I removed the home key and replaced to new screen but a small cable tore and unsure what exactly it does and how to repair. I took a picture but unsure how to upload. It's a small square to the left of the home key.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
Based on your description (I don't see pictures), you tore the delicate home button connector, and unfortunately, there's no way to replace this and retain TouchID functionality. The only way to regain TouchID functionality is to get a paired logic board/home button assembly. For security reasons, each TouchID sensor is binded to a logic board during manufacturing, so you cannot replace one or the other without replacing both.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Even though the home button still works? Any idea how much that costs?
door
I believe that the home button uses POGO style contacts to make a connection, and that only TouchID data travels through the ribbon cable. iFixit does not have any replacement parts for this particular model of iPad, but it is not a cheap or easy repair (>$300).
door
Ah, okay. Thank you for your help!
door
Het nuttigste antwoord
Afbeelding
This was torn off from the broken iPad
Score 1
Voeg je antwoord toe
Brenda zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 21
Altijd: 5,495
