Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Vragen Bekijk alle
Issues after housing replacement
I changed the housing along with a new lcd on my iPhone 6s plus.
When I turn it on. It sometimes works and sometimes doesn't prompting the plug in charger icon. But oddly it will actually turn on sometimes and after a 10 - 20 seconds will shutdown with no notice.
Does this mean the battery has been damaged during housing replacement.
Secondly the antenna on the top left wasn't coming off as I didn't know about the hidden screw under sticker and I ripped it off.
Now the little plate on the back has broken off but I sandwiched it back and screwed it down. Should I replace with new one?
Update (01/03/2017)
ok switched battery and now problem solved.
i have a new issue now. The volume button randomly presses itself especially the vibrate rocker? does the flex for volume need to be changed?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
original flex solved issue and it seems i had battery issue too. now all is working fine
Was dit antwoord nuttig?
Het nuttigste antwoord
Housing replacements are, oddly, more tricky than it sounds. The first problem could be a bad battery. The second problem sounds like you need to replace it with a new one for sure
I know you probably have figured this out. But I'll post a guide, just in case
This is the antennae in the top left
Score 1
1 Opmerking:
they all 6 plus parts buddy. ihave 6s plus
door
Voeg je antwoord toe
Obahan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 105
