Ga door naar hoofdinhoud
Model 1402 / 16 or 32 GB capacity
10 Vragen Bekijk alle
My zune does not turn on!
I have a zune HD i had it for a while and one day it did not turn on i thought it was because it was not charged but when i go to charge it nothing happens can any one help? And can any one tell me how to do the three buttpn rest? Please? And thank you.
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Just in case anyone else reads this, you fix this by holding down the power button for about 20 seconds.
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
I did not know about holding the power button down for 20 seconds. I thought my Zune had died but no this got it going again. Thanks.
door
Thanks I had the same problem, now I use ur 20 seconds method, it worked like magic, by the 18th second it off and on again.
door
Tried this. Didn't work. Is battery dead. 15 yrs old
door
I've had this problem a couple times, but as far as I can tell there's nothing you can do to really fix it. Usually if I just leave mine alone for a few days it will randomly start to work again.
Voeg je antwoord toe
alpta zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 31
Altijd: 6,703
