Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
knocked off components near battery connector
i tried a diy witha solder, not micro solder and knocked off all 6 components next to batt connector. please tell me if i can jumper all and if i can jumper any components conncetors together that wont affect my phone
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
There are four capacitors and two resistors. You can short the two resistors (R61 / R153) as they are 0 Ohm. The capacitors are there for filtering noise off the line so ideally, they should be replaced but your phone will work without them. If ever you see erratic behaviour, then you will want to replace them.
These components are tiny, measuring just 0.5mil X 1mil and they are in close proximity to the battery connector. This is by no means an easy repair unless you have the proper tools and some experience working at this scale. Please don't just assume you can use a standard soldering iron otherwise you risk damaging your logic board even further. There are plenty of videos on youtube that make it look easy but these folks are using multi-thousand dollar micro-soldering workstations under stereoscopic magnification.
If you don't feel comfortable doing this yourself, then look for a repair shop that does micro-soldering repairs. It shouldn't be a very expensive repair.
Was dit antwoord nuttig?
Score 1
5 opmerkingen:
Thanks for the answer, also can I not connect any components together like the first two, next two and last two together
door
Can the capacitors be jumped and what temp in Celsius should my solder be.
door
I'll repeat the answer: You can short the two resistors (R61 / R153) as they are 0 Ohm. The capacitors are there for filtering noise off the line so ideally, they should be replaced but your phone will work without them.
You don't short capacitors unless you want a non-functional board. What kind of soldering iron do you have?
door
I might have peeled of a little of the board and made the lower pads of the last two component that is the resistor and capacitor. What to do?. I'll attach the image soon. I have a lot of Flux there and have to clean it off
door
Voeg je antwoord toe
neal kaul zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 163
