Ga door naar hoofdinhoud
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
274 Vragen Bekijk alle
What glue do I use to reapply the flexible backing on the keyboard?
15" MacBook Pro retina Early 2013 2.4 GHz (Model A1398)
I had to do a teardown to clean chicken soup out of the keyboard and trackpad (no soup got anywhere else). I removed and cleaned the flexible backing on the keyboard assembly, and also cleaned the keys.
My question is this: What glue do I use to reapply the flexible backing on the keyboard?
Thanks.
Is dit een goede vraag?
1 Opmerking
I was worried that it had to be a kind of glue that could withstand the heat inside the computer without softening. But from the answer it would seem this is not a problem. Thanks.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You have a few choices here: Apple uses a hot glue, my personal choice is using 3M double stick tape.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
hfsolar16 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 307
