Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Vragen Bekijk alle
iPhone 6 plus stuck in DFU mode after replacing touch ic
I have fixed many iphones and I am good in microsoldering. I received this iPhone 6 plus for touch ic disease. When I opened the phone I noticed that some other technician has tried to re-hot the ic by using lots of Flux all over the board.
So I replaced the Meson chip to fix the touch issue. When I turn the phone on, it didn't turn on. I checked most of the required voltages and there is no shorting. When I connected the phone to computer, it detects the phone in DFU mode. There is no option of update.
What area, components or ic chip is responsible for DFU mode? Customer doesn't want to loose data that's why I didn't try to restore.
Has anyone encounter such a problem? Please share and help me to solve this issue.
Thanks
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
No chip is "responsible" for DFU Mode, unless you want to consider the CPU. You could try a software like ReiBoot to take it out of Recovery Mode.
I suspect the Meson replacement did not work perfectly, you may want to reflow it or change it again.
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
3Utools is currently the best software to use right now as it supports exiting recovery mode on all iDevices.
door
Minho is right. if it has been heated prior then the CPU is most likely the cause.
the best process with any fault is undo what you have done and start over. remove the driver and trackpad and power up without. this will eliminate the touch being the cause
door
I had similar issue after fixing new touch ic at shop and the phone worked fine for few weeks then enter dfu mode by itself and i never could take it out.
The guy in the shop said power ic is damaged and this problem has no solution
1 Opmerking:
Had the same issue, after heating the touch ic the phone won’t come on but went I connect it on my computer, iTunes detect it on DFU mode and if restore it, it also fails to restore. iPhone 6 Plus
door
Voeg je antwoord toe
Amir Vasaya zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 2,944
