Ga door naar hoofdinhoud
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
Mac Shuts down unexpectedly
Problem
My MacBook Pro works fine with a fresh installation of OSX.
When I install adobe products, it shuts down unexpectedly, even if the app is not open.
It crashes also with qbittorrent, and "console" from Mac utilities.
Cause
I've had to replace my Magsafe because it died (short circuits), maybe that there is a link.
Tried
I have tried to fully reset the system, the SMC, PRAM,...
Genius Bar
I brought my Mac to the Genius Bar, they did not find any problem. They said they did not encounter the problem (are they magician?) because the problem appeared 5 sec after they gave me back the macbook
Thank you for your help!
Is dit een goede vraag?
Score 1
2 opmerkingen
My Macbook runs without sudden Shutdowns when a hdmi dummy plug is plugged In. The logic board is damaged
door
I got the similar problem. it is fixed when I plug in a Thunderbolt-ethernet-card. Pretty strange ...
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
One option to look at is which video card you're using. For example, on mine, the integrated (Intel) video has gone out, and the computer is prone to system halts. If I have it on an external monitor, works fine. I currently have a utility, gfxCardStatus, to force it to use the higher performance card.
Was dit antwoord nuttig?
Score 1
Changing the battery did not solve the problem.
In that kind of cases, the Logic board seems faulty.
It is strange but the mac runs fine on windows...
Voeg je antwoord toe
alansaillet zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 14
Altijd: 406
