Ga door naar hoofdinhoud
Intel Core 2 Duo T5500 1.66GHz, 512MB RAM, 80GB HDD
11 Vragen Bekijk alle
memory parity error and blue screen death
when i start my computer sometime it tells memory parity error and sometimes Blue Screen of Death comes.I tried reinstalling windows but it did not succeed,it gets interrupted in between and Blue Screen of Death comes. Pls help me regarding this.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
You have a hardware problem which must be addressed.
The first thing to try is to remove and reinstall the memory. I'm not sure about this exact model, but the memory is most likely installed under a trap door on the bottom of the machine. The memory can be damaged by static electric discharge, and you must also be careful with the clips that hold it in place, as they are often made of plastic and can break easily if pushed too far.
To deal with static electricity, sit down, don't slide around, and always touch a metal part of the computer case before touching any components. There are various other precautions you can take, but those are the main ones.
You can search and find explanations for how to remove and replace memory if it doesn't look too obvious for you.
If, after removing and reinstalling the memory, you still have the memory parity error, then you have more work to do. First, if you have two memory modules, you should try removing one or the other and see if the computer works fine with only one. This will help you determine which module is defective.
Second, you may wish to purchase or otherwise acquire replacement memory. You might do this whether or not you were able to operate with only one module, since your computer will operate better if it has enough memory compared to having too little memory available.
Was dit antwoord nuttig?
Score 5
1 Opmerking:
Just download "I8kfanGUI" program enable manual fan control and set to high speed. its over heating problem i have myself one of those... best regards..
Score 1
Hi,
You can check the hard drive and the RAM to make sure that they are connected properly. Remove the panels in the back that cover the hard drive and RAM with a small Phillips-head screwdriver. Press the components firmly into their connections. This step is not recommended due to damage in customer device risk.
Check your computer’s temperature. Overheating can lead to your hardware malfunctioning. One of the most common components to overheat is the graphics card. In BIOS post test the computer shows on black screen at start up the temperature conditions of computer box. To check it customer can restart the computer and on first screen top right or left corner will show the information of temperature. If it is more than 40 celcius then it is more likely to crash the computer. Reseat the computer in a more cooler place i.e top of the table and away from the wall for venting purpose. The malfunction of processor fan can also be the reason.
Test your RAM. A common culprit in system crashes is a bad stick of RAM. When RAM fails, it causes the system to become unstable. Open the box unplug it from the Slot Remove the RAM clean it for carbon and dust particles and plug it back on make sure when you plug it back you hear the click sound.
Test your hard drive. Run the “chkdsk” function on your hard drive to scan for errors and fix potential problems. A failing hard drive can cause Blue Screens due to corrupted files. To run chkdsk, open command prompt and type CHKDSK entre.
Good Luck
Replace your RAM & HDD .............ok I hope the problem has been solved............
Voeg je antwoord toe
abhay zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 30,605
