Ga door naar hoofdinhoud
De MacBook Pro is Apple's laptoplijn voor recreatief en professioneel gebruik. Deze reeks bevat onder andere de MacBook Pro 13, 15, 16 en 17-inch modellen met daarin weer verschillende modellen die gekenmerkt worden door hun respectievelijke Unibody, Retina-scherm en Touch Bar-ontwerpen.
how to i get my wireless to work
how to create a wireless connection
Is dit een goede vraag?
1 Opmerking
Please be more specific with your question. Do you have router problems, or is the computer not working as it should?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Do you have any other devices which are connecting to your WiFi network? Are they working at the same physical location you are trying to setup this computer?
Look at the settings of one of the working systems to see what you need to set on system that can't connect.
The wireless Bridge or wireless Router (called an Access Point {AP} for either) may also require a given type of 802.11 service (A, B, G or N) or a given band in the case of 802.11n (2.4 or 5.0GHz) for your systems to connect to it. Make sure your system can access the AP's service type settings.
Some older MacBook Pro's can't access 802.11n networks without a firmware upgrade, or access the 2.4 or 5.0GHz bands
How to tell if 802.11n-enabling software is installed:
http://support.apple.com/kb/HT2447
Was dit antwoord nuttig?
Score 1
1 Opmerking:
If u have a wireless network that you might want to connect to,you reqire the SSID of the network from the network creator,otherwise your wireless wont work.
You can always check the wireless network strength.If it is too low then you wont be able to connect to the Internet.
All the above mentioned solutions are with respect to software alone.You might also want to check if there is any hardware fault with your wireless router or NIC.
door
Het nuttigste antwoord
Under System Preferences
Network - verify that your Airport card enabled.(turned on) If it's detecting a network (curved arches). If it is then the problem is with your router, check their directions or support pages.
Use Mac Help from Under Help in the Menu:
* Network, share, and go online
  • Your Mac lets you easily join wireless and wired networks, share with others, and exchange information quickly and efficiently while having fun with personal touches.
* Setting up or joining a network
  • '''Whether you’re creating your own AirPort network or joining a local area network at your home or workplace, you’ll find step-by-step instructions to assist you.
If this answer is acceptable please remember to return and mark it.
Good Luck,
N.
Score 2
Voeg je antwoord toe
paul zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 1,287
