Ga door naar hoofdinhoud
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Vragen Bekijk alle
Touch only working on second try
A customer brought me an iPhone 5, the problem is that always when the screen is off for a longer time (at least 10 minutes) and I turn it on again, the touchscreen isn't working right. When I turn the screen off and on again it works fine. What could be the problem? Already tried reconnecting the flex cables. Could the display be faulty?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
You could have a bad screen assembly. The logical first step is to replace it with a good quality part.
The iPhone 6 and 6+ are well known to have problems with Touch (Touch Disease) but this is not a common problem with the 5.
iPhone 5 Screen Afbeelding
Product
iPhone 5 Screen
$34.99
Was dit antwoord nuttig?
Score 4
2 opmerkingen:
Yep you nailed it.
door
I noticed an increase in temperamental behaviours with touch on a couple iPhone5 after updating to ios 10. Might be a coincidence, but...
door
there is a prossesor that starts to loose its conections due to the phone being subjected to bending.this prossesor is responsible for touch recognition.ifixit can show you wich one it is so you can replace it if it is economical to do so.There is no guarantee this is the issue but i would put money on it.good luck and always have fun fixing.
Voeg je antwoord toe
ppalfinger zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 80
