Ga door naar hoofdinhoud
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Vragen Bekijk alle
Power - on Failure (mostly)
IMAC 20'' 5.1 late 2006
Hallo,
I have a "funny" failure with my 20'' IMAC.
First - month ago - he didn't want do start with the first try, but he came...
But it was getting poorer - and after a longer time and not using he wouldn't start.
The power-supply was not ok. One capacitator war blown. I changed it.
I changed the big 150mf 420v too.
First: no succes. LED01 is blinking.
The ventilator "tries to turn". (neerly not to see, so little)
But: if the IMAC ist connected to 220V and I seperate the connection that comes from the power-supply on the mainboard and put it together after some secondes, LED 01 ist ok and the IMAC works.
Anny idea to fix it?
Thanks
cpg
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Your diagnostic LED indicates you still have a PSU power supply issue. Replace or repair it.
here's how:
iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
peter zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 79
