Ga door naar hoofdinhoud
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
Detached home button cable
I opened my Iphone SE case too quickly/far and the cable came unsoldered. Which part do I need? I found the cable alone and the full home button. It appears the button is fine just the cable needs repaired. any links to parts/guides would be much appreciated :)
Is dit een goede vraag?
Score 3
1 Opmerking
Can you attach a picture to your question? That way we can see if it's fixable or not.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
it sounds like you've torn the touch ID ribbon cable, you can replace the home button for a third party one but will lose Touch ID functionality, it will only work as a home button. Only apple can recode your phone to accept a replacement touch ID button. Unfortunately touch ID will be disabled unless you want to pay apple to do the repair.
Was dit antwoord nuttig?
Score 2
Did you rip the cable? If it just came unplugged from the Lightning connector, just plug it back in. If it is ripped, your screwed. Bring it to Apple. Sorry :(
Score 1
Voeg je antwoord toe
Derik B zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 1,011
