Ga door naar hoofdinhoud
This HP laptop was released in 2014 and is pre-installed with Windows 8.1.
6 Vragen Bekijk alle
Why is my screen black and unresponsive
Hello,
So recently after not being on my laptop for roughly a week, i decided to go turn it back on to do some work. But it didnt... The screen stayed black and all i got was power to the keyboard and the caps lock button flashing at 3 second intervals. Consistently, Like it will do that for hours. Ive drained the capacitors restarted it, and nothing. What happened ? I havent dropped it or anything. Ive taken it apart. Re-seated everything... Help ! Im thinking it may be in a boot cycle but i dont know....
Is dit een goede vraag?
Score 1
4 opmerkingen
Please someone help
door
How many times does it flash, if it were doing it in a repeated sequence?
door
@brittkwa just 1 flash, then the long wait (Probable not 3 seconds) but a long pause then another single solid flash and that's it. It will continue that cycle consistently until power is removed
door
@brittkwa i went and tried that, (Applies paste too) and still noting
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
If it's just 1 flash of the caps lock light, it needs the CPU reseated or replaced. You mentioned reseating everything, so it looks like the CPU is faulty.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Jarrod May zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 243
