Ga door naar hoofdinhoud
American Edition released in 2013, identified by model number X502CA
11 Vragen Bekijk alle
Stuck in bios mode after updating to windows 10
So yesterday I was updating my computer and it was downloading windows 10. It got all the way to 100% before it froze for about 2 hers. When I restarted it, it immediately went to Aptio Setup Utility. I have tried everything mentioned. Taking it apart, turning it on and off again, enabling and disabling you name it. Before updating my computer there was literally nothing wrong. Now it seems Im &&^&@@. Has anyone else had this issue when updating?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Go on another working computer and make a Windows 10 install/recovery media by going to this link and following the instructions
https://www.microsoft.com/en-us/software...
Insert the disk into the computer and boot up. In the bios, go to the boot tab and select the usb drive under boot override.
You should be booted into the windows recovery disk. Do not remove the disk. Go to repair my computer and select automatic recovery. If that does not work, then you will need to perform a fresh install.
Was dit antwoord nuttig?
1 Opmerking:
Yup .... that's the only real way
door
Voeg je antwoord toe
Frank Rojas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 996
