Ga door naar hoofdinhoud
The VTech InnoTab 2s is a kids education tablet that teaches them to read, write, and think logically and creatively.
Why is my device not turning on?
I'm pressing the power button on my tablet but it's not turning on.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
If your device is not plugged in using the VTech® recommended Power Adapter, then your batteries could need replacement. Check to see if your AA batteries aren't depleted. Try plugging in your device using the Power Adapter. One of these suggestions should help you with this issue.
If you plugged in your Power Adapter and you're still not able to turn on your tablet, then you might have an issue with that Power Adapter or with the power connecting port on the device. Consider replacing the power adapter or replacing the power connection port. If you replaced the batteries with working batteries and your device is still not powering up, then you might want to consider replacing the circuit board.
Was dit antwoord nuttig?
Score 3
Ensure that there are new batteries installed into the device. If using the power supply make sure that the power supply is plugged into a working wall socket. If it is plugged in properly you may need to replace the power supply socket, a guide can be found here for it.
Score 2
Voeg je antwoord toe
Esthevan Romeiro zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 1,697
