Ga door naar hoofdinhoud
The Polaroid PMID4312 is a 4.3" tablet that features a multi-touch display, front facing camera and utilizes the Google Play store to obtain apps.
5 Vragen Bekijk alle
My touch screen does not work
I tap on an app to open it but nothing happens. It takes multiple presses just to get something to open. It is very frustrating. Please help!
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Sounds like the digitizer might be loose on the inside. You would need to open it up and look and reconnecting the ribbon cable. If that doesn't work, you may need to replace the digitizer. You can find replacements on ebay with your model number.
Was dit antwoord nuttig?
Well my screen is cracked and it won't let me tap on any thing the only thing I can do is turn it off and wait till the screen will dim and turn off
1 Opmerking:
Then you need to replace the screen and the digitizer.
door
Voeg je antwoord toe
Christopher Bertan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 450
