Ga door naar hoofdinhoud
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Vragen Bekijk alle
no touch on portion of screen.
just recently replaced LCD assembly and now there is no touch detected through the middle of the screen horizontally. what might cause that to happen?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Did you replace it yourself or did a store replace it? Check the digitizer cable if it's plugged in fully.
It's very common for it to become loose before installing the metal plate that goes over the screen connectors.
I usually just push on the metal plate or make sure it stays in when I install the metal plate.
Was dit antwoord nuttig?
Score 4
Voeg je antwoord toe
Doug Chalmers zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 56
