Screen repleaced but still touch no redpond
Bought new screen repleaced but still no redpond to touch
Is dit een goede vraag?
Try cleaning the cleaning the connectors on the board and the screen with a toothbrush and isopropyl alcohol.
Make sure they are seated well, and make a satisfying click when put in place.
Inspect the cables for pinches or tears, especially close to where they connect with the lcd. Just a little bending there can cause failure.
Potentially look for a third screen to do a definitive test.
Was dit antwoord nuttig?
This isn't a problem with screen of iphone but with touch sensors that is on motherboard. Check for any videos in iFixit how to replace touch sensors of iphone that you have.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 62
With the original screen plugged in, does the touch screen fail to work as well? or did it stop working once you installed the new screen? If you have tried multiple screens, and the touch still doesn't work, i would take a look at the motherboard to see if any of the connectors are damaged
door Tech Disassembled
With original screen work fine but was crack i repleaced and work ok start unrespond to touch little by little after three months no respond at all so i repleaced 2 nd screen from ifixit and now no respond at all.
door porfirio bravo
Wher can i take for second opinion just to check for small fee anybody ?
door porfirio bravo
door Anis Bakiu
May be your touch IC is dead.
door emmacorsa17
