How do I find Top dead center
I need to know how to find Top dead center on an 88 GMC. does anyone know how? Do i have to have a timing light?
Is dit een goede vraag?
If your just looking for TDC you do not need a timing light . first you need to find the number one cylinder then remove the spark plug . Turn the engine by hand (use a socket and bar on the crank shaft ) until you have compression stroke . You can tell by putting your finger over the hole and feeling the air push against it . Once you have the compression stroke look on the crank pulley , there will be a mark to indicate TDC. align this mark with the timing mark , usually just off to the side of the pulley with makings on it. This video should help
Was dit antwoord nuttig?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 35
Afgelopen 30 dagen: 177
Altijd: 17,697
