Ga door naar hoofdinhoud
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, and a better design.
368 Vragen Bekijk alle
Power light turns on, but the speakers pop and it turns off.
So I was letting my 5 yr old brother use the device (foolish, I know, but I'm just too nice a guy for my own sake), and he dropped it on the ground. It immediately shut off and now what's happening is I press the power button, the light goes on, stays for a few seconds like usual, but then the speakers "pop" and the whole thing is off again. I tried opening it up but couldn't find anything I could recognize as out of order, but then again I didn't really go that deep. Does anyone know how to fix this?
Is dit een goede vraag?
Score 5
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
You should check the ribbon cable connection also may have a bad/broken fuse. You will need to test current of the fuses if the ribbon cables are fully seated.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
How do I check those fuses?
door
How do you check the fuse
door
The same thing is happening to me but one of the cables of the speaker is broken
1 Opmerking:
yeah i have the same problem but i spilled pop on it
door
Voeg je antwoord toe
Ace in the Hole zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 614
