Ga door naar hoofdinhoud
The Coolpix P530 is a 16.1 megapixel digital camera with an impressive 42x optical zoom. This model was released by Nikon in February of 2014. It also goes by the manufacturer specific model name Nikon 26464 .
20 Vragen Bekijk alle
What is this flashing red square with possibly a clock symbol?
A red flashing symbol is flashing (it's right over the battery symbol). I do not know what it is so I do not know how to fix it to stop it from flashing. Can you please help me in fixing this problem? It's a red square with what looks like a white circle resembling a clock with a 9:00 read out and has another dot where the 3 would be.
I'm expected to take a trip in the next week and really need my camera. Thank you for any help.
Is dit een goede vraag?
Score 13
3 opmerkingen
I also encountered the same issue , the first answer was perfect as it is related to time zone setting. Once you manage that by getting it correct in your camera settings, issue get resolve the then and there only.
door
Thank you so much, it worked it was the "Time Zone Setting" but why is it not in the Manual?
door
Thanks. It worked well
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
The date and time are not set on your camera. Using your camera's menu, try setting the date and time on the camera. If you can't figure it out, look up your camera's manual online and read about how to do it.
Was dit antwoord nuttig?
Score 15
5 opmerkingen:
Very helpful. Sort of obvious in retrospect. But hadn't figured it out. Thanks.
door
Thank you!!!!
door
Did that it says failure to link to satellite.
door
Thanks so much! Flashing icon disappeared when I set time zone and date. This was driving me crazy and was NOT mentioned in 147 page owners guide! You are my hero :)
door
oct 2024 - Thank you, I set a time.
door
It refers to the time zone setting. My daughter just showed me!
Score 5
2 opmerkingen:
What she said ^
I
door
It means you need to go to the menu and set the date.
door
Sorry if this doesn't help but I'm not quite sure what this mean but on some cameras it might mean that the flash is on that the camera is dying, try charging it.
~Hope this helps!
1 Opmerking:
The other comments are all wrong! I tried all those steps My 2016 nikon coolpix B500 doesn't need to be charged, new batteries, or a time adjustment! I dont have the original user guide and doubt it would be in there anyway. When I figure it all out i will be back with troubleshooting needed to fix this problem! To the person who asked this question...horses hold em...brakes pump em, the mind body and soul...relax em, jets...cool em, nerves...calm em, roll...slow it, excitement level...lower it, anxiety...push thru it, your worrying...outta sight/outta mind it, listening to the other comments...dont do it, your simmer...turn it down, panic level...turn it down, voices in your head...turn them off, let me take the wheel...(((everything I listed was just a joke and not at meant to offend you, be mean to you, or hurt you in any way💞💖)))I,ll be back with answer ASAP!
door
Voeg je antwoord toe
Janice Rogers zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 32
Afgelopen 7 dagen: 247
Afgelopen 30 dagen: 856
Altijd: 84,897
