Ga door naar hoofdinhoud
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
300 Vragen Bekijk alle
What SMD is this?
Hi
Accidentally i had a short circuit on my Macbook
Because the isight cable was damaged.
As i started the Macbook a SMD was glowing
Now its broke and lost.
I want to know what smd that was.
It is next to the connector of the isight cable
Update (14.11.2016)
Has nobody an Idea ?
Is dit een goede vraag?
1 Opmerking
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
L3405 and the capacitor next to it is C3422 (capacitor burn might clean up with isopropyl though).
L3405 = 120 ohm 1.5A 0402 ferrite bead
C3422 = 0.1uf 20% 10V 0402 capacitor
Was dit antwoord nuttig?
Score 1
5 opmerkingen:
Thabk You so much for your help.
So the burned one is L3405?
And c3422 is under the burned one or the right one?
I think i just change the burned one l3405
door
Destroyed one is L3405, C3422 is to the right of this. Yes, just replace L3405 and clean the burnt capacitor, usually it is just residue, the capacitor should be ok.
door
https://www.conrad.at/de/smd-ferrit-120-...
Would that one be ok?
I cant find how much A this has.
door
Yes that looks ok. Might be worth emailing them to check the amperage though. Just email them, say you're looking for a 120 ohm 1.5A 0402 ferrite bead and they will point you in the right direction.
door
Insaw the Soldering point on PIN17 but i cant find the other soldering Point
door
Voeg je antwoord toe
PKremsmair zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 179
