Ga door naar hoofdinhoud
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
312 Vragen Bekijk alle
keyboard and trackpad not working
This was my first macbook air. I like it a lot, but I rarely use it. Well, I have a lot of computers at my house.
Since last year that I purchased the newer macbook air with the ssd, this was not doing anything much.Now this year with the ipad, even less.
However something strange happened to this macbook air when I took it out and try to sell it on ebay.
Let me explain. When I power on the laptop, right away, I hear the familiar apple boot sound. Then the laptop continue to boot. And finally
when it finish boot, I try to use it, the trackpad does not respond, so is the keyboard. I was thinking it may had crashed. But when I press
the power button. The shutting down message appear. So I know the computer did not crashed. I plug in a usb mouse and it worked. After
I turn it off and on a couple times. The keyboard and trackpad came back to life again. Then I put up the laptop. But the next day when
I tried it again. Samething happened. But eventually they work again.
Here is what I find out. If the trackpad or keyboard don't work, they don't work at the same time, never alone and since they are both usb,
they don't show up in system profiler. I tried press shift+control+option+power, the laptop turns off. So the keyboard maybe working.
I tried reinstall the system fresh, same thing. I will say one of 20 tried, the keyboard and trackpad will work. Maybe more, not too sure.
When it work, they appear in system profiler.
 any boady knows wich is the problem in my mac
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Well I've just had the same problem with a MBA late 2008.
The keyboard and trackpad wouldn't work at all - not even at boot time.
The USB port wasn't working either - it wouldn't boot from an external DVD drive.
I checked all the cables, looked for damage/spillage too - nothing.
Then I noticed that the late 2008 model has an nVidia 9400 chip in it. Could the USB ports/keyboard/trackpad be driven from the nVidia chip? I checked out the hardware description on the web and found that it does indeed drive the graphics as well as the USB, SATA, etc.
Knowing the nVidia chips around this era had issues with dry joints, I thought a reflow may be my last chance. So, out with the reflow station, let it cool and put it back together.
Powered on the MBA and the external DVD drive fires up, the keyboard and trackpad work too.
So, if you have the same problems, a reflow of the nVidia chip may fix it once you've tried the cables, etc first. I believe there are many services on the web that offer reflows on these chips.
Thought I'd share this with everyone!
Was dit antwoord nuttig?
Score 2
Het nuttigste antwoord
From lack of use the connections may have built up some resistance on the connections for the keyboard and trackpad. Open up the computer and clean and remake the connections. If this doesn't work let us know and we will look further.
MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement
Score 2
I'm having this exact same problem. I have replaced the trackpad control cable and the top case... I fear that it is a bad logic board..
Voeg je antwoord toe
jaime ruiz zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 13,461
