Ga door naar hoofdinhoud
Geavanceerde gps voor vrachtwagens, uitgebracht in 2015, uitgerust met spraakbesturing en eenvoudig te gebruiken in elke vrachtwagen.
What can the SD card be used for?
The SD card slot allows for expanding the memory space on your GPS so that you can store extraneous files such as music, audio books, and videos. The SD card slot accepts microSD cards of all memory sizes.
Is dit een goede vraag?
1 Opmerking
This is not a fully true answer!!!! You can not read books... you can not listen to stored music nor watch videos or store some other form of misc. files on the Garmin Dezl 770 Trucking GPS! This is strictly a professional GPS. What a bogus answer!
door
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
I understand that you are a student, Think of this place like Jeopardy. Answer and question. You made a statement. Also what type of SD card does it use? What sizes are available? Where can you get the right one? Does it need to be formatted before use? Is there a guide on the main device?
Was dit antwoord nuttig?
Score 2
I put a 32 gigabyte card in, manually copied all files over except the garmin directory. It works fine but when you turn it on you have to remember to say no to backing up files on the main unit. If you choose yes it will not use the SDCard and revert back to using the units memory to store all POI’s etc.
Voeg je antwoord toe
Savan Dave zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 22
Altijd: 2,429
