Ga door naar hoofdinhoud
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 Vragen Bekijk alle
Power Flex Cable Replacement Issue
So i seen the power flex on this ipad was bad, could see there was a tear. So i replaced with another and of course the adhesive on it is terrible nothing wanted to stick in place. So i used a bit of super glue. Now Iam not sure if this caused an issue or not. When i first got it all connected and in place, I tested Boom Ipad comes on No problem. Seal it all up. Nothing will not power on via the power button. Connected it to the power cord, comes up. I removed the power flex again and looked at the cable it does not look "damage" But i am wondering if the super glue could have damanged the flex?
Something else i can try?
Any suggestions are helpful
Thanks
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
I would order another power flex cable. Its clear that the cable is damaged if it is no longer working and power on when plugged in. Very easy thing to do while replacing the screens on these.
Was dit antwoord nuttig?
Voeg je antwoord toe
mikebarkas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 58
