Ga door naar hoofdinhoud
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 Vragen Bekijk alle
Replacement keyboard of a MacBook Air 13-inch mid-2011?
Hi
My shift key has stopped working and the service centres have recommended that I replace the key board.
Why is there no iFixit manual for keyboard replacement? Where can I purchase a replacement keyboard?
Cheers
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Best place to purchase the keyboard is from eBay for under £20. The keyboards on this model are stamped into the aluminium with rivets, so you have to pull the keyboard out, then pull out the rivets using a wire cutter. This will leave holes for you to secure the new keyboard with small screws (search "a1369 keyboard screws" on eBay". Before pulling the old keyboard out, plug in and test the new keyboard to make sure it works, and is a keyboard issue, since it could be caused by a damaged keyboard connector on the trackpad.
Just follow the guide on ifixit to remove the logic board. Then you have to remove the speakers by sliding a thin tool (painting knife) under them, do not pull out the speakers. Then remove the black keyboard backlight (depending on model), so you can access the keyboard. Remove the outer screws and then rip the keyboard out.
It is easy to mess up pulling the rivets out of the casing, you have to have a tight grip (not too tight, otherwise you will cut clean through the rivet), then tilt the wire cutter to pull it out. If it slips and damages the rivet, grip it again and rotate the rivet until you see the rivet starting to rotate, then you should be able to tilt and pull it out.
On Youtube, search "a1369 keyboard replacement", will be videos of people doing this.
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
The suppliers on eBay I have used offer just the keyboards or the keyboards with screws.
door
That's right, some do offer it with the keyboards. I prefer to get them separate though from China, can get the keyboard for 10$ and screws are 1$ a bag of 50-60.
door
Reece, would you mind updating your profile so you lock it your user name and we can notify you in other questions with the @ sign. As far as I am aware none of us know how to repair the Retina displays yet and your expertise on this would be very welcome.
door
Sure just done this, feel free to contact me if you need any advice on these. Done all models other than the newest 13+15 models.
door
Voeg je antwoord toe
Shahid Hussain zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 1,288
