Ga door naar hoofdinhoud
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
597 Vragen Bekijk alle
Keyboard working but power button not working
hello all,
i recently did a logic board replacement. At first it worked good but after some time i started getting problems:
The keyboard works but the power button does not. I have to turn it on by disconnecting and reconnecting the battery, then reconnecting the charger.
Secondly,
it shuts off with the slightest push on the left side(when its unbalanced, like on my lap).
After that it automatically restarts a few times after which it finally gets to the OS.
I've already tried disabling the sudden motion detector but it does not work.
So any suggestions??
Thanks in advance.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
We are starting to see several cases of failed power buttons that require a keyboard replacement. Here's my question on it from a couple of months ago: Will not power up unless SMC reset is done
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Talha Siddiqi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 88
