Ga door naar hoofdinhoud
Apple's 2016 revision to their laptop lineup targeted at professional users. Features a 15-inch, 2880-by-1800 Retina display, quad-core Intel Core i7, 256 GB / 512 GB /1 TB / 2TB storage options, 16 GB RAM, and a keyboard equipped with a Touch Bar. Released November 2016. Features Model A1707.
245 Vragen Bekijk alle
Is the ssd upgradeable on MacBook Pro 15" with Touch Bar
I purchased a 256 GB model, and wish to upgrade SSD.
Is that possible?
Is dit een goede vraag?
Score 9
15 opmerkingen
No it is not. The SSD is soldered to the motherboard.
door
No, the SSD is NOT soldered to the motherboard.
door
Alex, the SSD on the MacBook Pro with touch bar is soldered. You can't replace it.
door
But, could someone un-solder it and replace it that way? Are the parts out there? Just curious...
door
10 commentaren meer tonen
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
The SSD is soldered to the motherboard. You will have to return it and get the one you wish or do some very risky de-soldering which has a 1% success rate.
Was dit antwoord nuttig?
Score 4
3 opmerkingen:
IMHO it is not soldered. I saw some openbox videos on 13' model. Are you sure?
door
Yes! The Touch Bar version systems both have soldered RAM & SSD. Only the new function key model has a removable SSD and its a different interface than what Apple had been using.
door
Gotta return it!!
door
Get buyers remorse. Take it back and get the model you need or you may be stuck with it for a couple of years until OWC comes up with a replacement. See their blog here:
http://blog.macsales.com/38440-ssd-in-la...
Score 1
1 Opmerking:
@mayer - Sorry the new touch version MacBooks Pro's don't have a removable SSD! Here's the poop: 15-Inch MacBook Pro With Touch Bar Has Non-Removable SSD The 13" is no different.
The new function key version 15" MacBook Pro Does have a replaceable SSD! But, its still a different interface than the older SSD's Apple has been using. Which is what your link is about.
door
Voeg je antwoord toe
Yao Meng zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 146
Altijd: 63,535
