Ga door naar hoofdinhoud
A1708 / EMC 2978 — Released October 2016, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). The function key version packs an Intel Core i5 and two Thunderbolt 3 ports.
216 Vragen Bekijk alle
Can the SSD be switched out?
Can the SSD be switched out and upgraded ?
Is dit een goede vraag?
Score 8
Voeg een opmerking toe
7 Antwoorden
Het nuttigste antwoord
Looks like the entry level 13" isn't soldered
OWC noted the following points in its teardown.
– Bottom was more difficult to remove than previous generations, but it was not glued.
– Speaker module needs to be removed to pull SSD back.
– SSD had very strong tape covering the interface port.
– Laptop automatically turns on when you open it regardless of pressing power button.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
If you review the OWC vid you'll also see the SSD module is very different from the older systems and it looks like a custom part! So, even if its removable, it will be a while before we see a 3rd party option.
door
@danj Yes I saw that! Hopefully the wait isn't as long as it was for the Retina models!
door
http://blog.macsales.com/38440-ssd-in-la...
Score 1
Yes, Please look at
Score 1
Yes. But so far no one has made an SSD that is compatible with this model, the first few will begin to pop-up within the next few months.
Score 1
Yes is it removable.
Update (10/31/2016)
2 opmerkingen:
Do you have a back up link on this?
door
I would like to know where you got this information. Nothing on the internet says Soldered, but I wouldn't put it past them
door
Anyone here who knows the pinout of the new SSD?
Adapter for MacBook Pro 13” 2016/2017 nTB
https://www.globalmac.cl/Adaptador-SSD-M...
(Chile)
Voeg je antwoord toe
benkuza zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 8
Altijd: 7,928
