Ga door naar hoofdinhoud
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Replace SSD with models from 2015.
Hi
Can I replace original M.2 SSD with something like SSD 960 EVO NVMe M.2 1TB ?
Will it work at all? And can it support the speed of storage?
original is 500 MB/s write and reed, and on link is 1900 write and 3200 read MB/s.
Thanks
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Sadly, no.
Apple uses a different physical interface from the M.2 SSD products you can buy from Samsung. While many of the SSD's Apple uses are made by Samsung they are OEM.
There is a 3rd party that does make a compatible SSD OWC - SSD Upgrades for MacBook Pro with Retina Display 13" & 15" Late 2013, 2014, & 2015. Or, you'll need to find a used unit on eBay which can be a bit of a gamble.
Was dit antwoord nuttig?
Score 2
Yes you can with this adapter: http://eshop.sintech.cn/ngff-m2-pcie-ssd...
but only Linux or Windows installer will detect the drive. MacOS doesn't support NVMe for OS booting at the moment.. maybe in future.
Score 1
2 opmerkingen:
So apparently the MacOS High Sierra will support nvme ssd out of the box. :)
www.insanelymac.com/forum/topic/324306-nvme-native-support-in-1013/
door
Good find!
mmm... I'll need to check it out once I get the needed parts. Remember High Sierra is in Beta so we'll need to wait till the full release to be sure they don't close the door on us ;-}
door
Voeg je antwoord toe
Volodymyr B zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 324
