Ga door naar hoofdinhoud
The Motorola XOOM 2 Media Edition is a Wi-Fi only version of the XOOM 2 tablet by Motorola. It has an 8.2-inch LCD display a black rubber body with an exposed metal panel on the back.
Why can’t I connect my Xoom 2 Media Edition to Wifi?
My Wifi is turned on but I am unable to connect to any Wifi network. Why is this?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Try turning it off and then on again. Make sure you login to the wifi you are trying to use if it requires a password. Does wifi work for your other devices? It could be that you have too many devices trying to run off one router. If it won't connect to public wifi like at a coffee shop, it could be your settings are wrong or maybe the antenna inside is messed up. Make sure your setting is set to "always" under "keep wifi on during sleep." If that doesn't improve it, you may want to replace the internal antenna. Hope that helps.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Google SUCK'S::::::::My Paaw
door
My password should be. "I Hate GOOGLE"!!!!!!!
door
Voeg je antwoord toe
Kara Monroe zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 43
Altijd: 437
