Ga door naar hoofdinhoud
MacBook Pro-modellen met 13" beeldschermen.
9745 Vragen Bekijk alle
Accidentally Erased Hard Drive...
Posting for a friend - although I've also done this in the past:
I meant to run First Aid on a client's internal drive, while booted from a different drive, but instead I accidentally erased the internal drive (!!!).
I have Data Rescue, and am running the Deleted Files scan now. But from my understanding, it does not recover any of the original directory structure or filenames.
I have not written any data to it - the only thing I've done since the erasure is initiated the Deleted Files scan.
Do I have any options for restoring the client's machine to its pre-erased state?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
At this point your best option is to run a recovery application such as the one you are currently running. I am not aware of anyway to "unerase" the drive. Given the drive has not been booted and a secure erase was not performed most of the files should be on the drive. Some recovery programs will recover the name as well.
Was dit antwoord nuttig?
Voeg je antwoord toe
Colin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 78
