Ga door naar hoofdinhoud
Released in Japan on December 12, 2004, in North America on March 24, 2005, and in Europe on 1 September, 2005.
Why wont my PSP 1000 charge?
ok so i've got a psp 1000 and i can get it to turn on it plays games fine but charging does not happen it wont even run on the power cable when the battery is not in the psp does anyone out there have any idea what is wrong and do you think it can and should be saved
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Well its ether one of two(maybe both)
1. you port is bad, depending on how long you have had the psp the port can get worn out. try blowing on it or buying a new port then replacing it.
2. The battery is bad. the battery can be shorted out. ether replace it with a known working battery or buy another
From experience I say its the battery but for my brother it was the port.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
This is old, I know, but there seem to be other issues as well. My Port is clearly fine (measured if it provides power to the board and it does, battery is new. Still no luck.
door
I was trying to add a USB c port and when I tested it, there was a little smoke and I think I blew a fuse. Trying to find the fuse is the hard part.
door
my experience says you need a new battery. there is a chip inside where software will allow the PSP to run. Hence why people use Pandora Batteries to hack the PSPs
see if u have a friend that will let you borrow their battery before you purchase one, that will be appropiate.
he is super right
my psp wont open too and i replace my battery with my brothers battery
and they both work fine
Voeg je antwoord toe
Ben zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 44
Altijd: 9,883
