Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1488 Vragen Bekijk alle
iPhone syncs to computer but won't charge - What do I replace?
I accidentally slept on my iPhone last night and broke some things. :-(
The display backlight is gone so I know I'll be replacing the display assembly.
The other issue is that the iPhone no longer charges when plugged in, either to a computer or a wall adapter. This has been tested with multiple cables.
It still syncs fine with the computer, it just doesn't pull any power.
What do I have to replace to make it work?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sounds like you need a new battery too (if not, then you have to replace the whole logic board, so I'd try the battery first).
Was dit antwoord nuttig?
Voeg je antwoord toe
CStigler zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,745
