Ga door naar hoofdinhoud
One of the highest rated weather reading systems in 2016. Tons of features and functions for the meteorologist hobbyist in all of us.
10 Vragen Bekijk alle
How to get weather center to stand straight?
I’ve attached my weather machine to the end of a long pole then inserted that into a deep hole I dug for it to go in. The machine wobbles and doesn’t seem to be as secure as it should. Is there a preferred way for installation that works better? Any suggestions?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It is important to secure your acurite weather center to a sturdy, strong foundation. If you are simply putting your machine on the end a a pole and sticking it into the ground, that may not be the best approach. Try constructing a type of foundation like this:
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Ben Kegel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 200
