Ga door naar hoofdinhoud
My dell Tablet is not turning on
well when i go to turn on my dell tablet by android it starts up normally then cuts in and out then goes to a black screen is there any way to restart it or do i have to send it some whare to fix it or is it easy to fix and i can do it myself
Is dit een goede vraag?
2 opmerkingen
Hi, What happens if you start it with the charger connected and switched on?
door
well when connected to the charger i shows up fine it shows it charging and gaining a charge but when turning it on with the power button it still does the same thing as i posted it will start up fine then flickering like cuting in and out then it just stops showing that it is charging and goes to a black screen with colered lines on the bottem
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It sounds like it is a bad battery that isnt holding a charge. I think it would need to be replaced.
Was dit antwoord nuttig?
1 Opmerking:
well maybe but i dont know whare i could buy a battery and for how much and whare can i send it to be replaced or fixed
door
Voeg je antwoord toe
Damien Valencia zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 794
