Ga door naar hoofdinhoud
Repair guides and support for coffee makers by Keurig including the K-Cup systems.
495 Vragen Bekijk alle
model k48 keurig lights flashing
My model k48 has been unused for several months, but still in the house and upright. When I plugged it in, all the lights started to flash and would not stop. Customer service was of no help and offered me a discount on a new one. Anyone have a solution other than buying a new one? Thanks.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Try resetting the Keurig by pressing the auto-off and both the cup size buttons simultaneously. All the lights should go dark and then return to normal. Thanks to Amazon user PJP for the suggestion!
Was dit antwoord nuttig?
Score 5
7 opmerkingen:
Did the trick...Thanks
door
I did what you said and it fix my keurig machine thank you very much for your solution.
door
Thanks for the tip. Enjoying a fresh brew right now
door
Thank you!!!! It worked!!!
door
What worked, I don't see a solution?
door
2 commentaren meer tonen
Thank you, it worked!
Did not work. Still flashing Ugh
1 Opmerking:
Tried every solution....unplugging to reset,cleaning needle,making sure water tank is sitting ok and pressing simultaneously the large and medium cup sizes.All lights are still flashing.Even tried a new outlet. Keurig is out the door ,I am back to a reliable drip coffee maker
door
Voeg je antwoord toe
nicklomele zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 46
Afgelopen 30 dagen: 226
Altijd: 20,634
