Ga door naar hoofdinhoud
Een gameconsole voor de televisie, geproduceerd door Sony Computer Entertainment, ook bekend als de PS4. Voor het eerst aangekondigd op 20 februari 2013 en gelanceerd op 15 november, 2013.
1697 Vragen Bekijk alle
Help! I ripped power supply connecter from the motherboard
I was taking my ps4 apart for cleaning when I accidentally pulled too hard and ripped the connecter from the motherboard. Do any know if it's fixable or do I have to buy another motherboard.
Is dit een goede vraag?
2 opmerkingen
And my warranty is up so, no use in sending it to Sony :(
door
The same thing happened to me during disassembly. I looked everywhere for somebody that had the same problem and couldn't find anything. Stumbled across iFixit and had it back up and running by the next day. THANX
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
As long as the pads are still on the board, you can repair it fairly easily. The 4 legs on the connector just need to be soldered back to the 4 pads on the board.
Was dit antwoord nuttig?
Score 2
5 opmerkingen:
thanks for the answer. Now I just got to find someone with a soldering iron :)
door
How should I solder it back, should I do it one leg at a time? Or does it not matter how I do?
door
I would clean up the existing pads on the board, by rmeoving the old solder using wick, then add a little fresh solder to each pad. Then solder each leg one at a time. It doesn't matter the order or exactly how you solder them, but you want to be careful of the surrounding components. you don't want to damage any of them. It should be fairly simple for someone with experience, but if you are doing it yourself, you may want to see if that metal cover on top of the board comes off, to give you more room to access the pads.
door
Thanks, I got a friend who's experienced with soldering, so I have worries about making any other mess. For anyone who is thinking about cleaning your ps4, please take you time and don't rush.
door
So did you ever manage to solder the power supply back and did it work? Because I'm having the same problem as you
door
I would solder a" brand new" connector to the cable at the very least and make sure to check the board for obvious damage first? If the mobo is . Then donate the machine to your local repair shop for the afternoon! D
1 Opmerking:
Where can I buy one
door
Where can I buy a brand new connector
Voeg je antwoord toe
Quaymetsu zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 2,336
