Ga door naar hoofdinhoud
De Acer Iconia One 7 is een tablet die in april 2014 werd uitgebracht. De Iconia One 7 is een compact pakket vol mediaplezier. Met een display dat groter is dan bij een phablet en dat zowel helder als kleurrijk is, krijg je een snelle respons en urenlange batterijduur om door te kunnen gaan. We hebben ook ons Kids Center-platform toegevoegd met veel toffe dingen voor kinderen, die ouders kunnen beheren.
black screen - can't use it.
hello everyone,
I just needed some help with my Acer Iconia one 7 B1-770. I hit the display brightness/darkness at its minimum and found out I can't see nothing at all. I thought there might be issues with low battery but when I pressed the volume, I could hear any sound. Unfortunately, I cannot use my tablet anymore.
Does anyone could help me how to fix this issue??please.
Thanks & God bless.
Is dit een goede vraag?
Score 1
2 opmerkingen:
Hello, have you tried a factory reset? Follow these steps:
1. Power off the tablet.
2. Press and hold the Volume up button, which is located closest to the touch screen lock switch.
3. While holding the Volume up button, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
4. Once the tablet screen turns on, stop holding the buttons.
5. On the Android system recovery screen, select wipe data/factory reset. Use the Volume up and Volume down keys to navigate through the menus and use the Power button to select the desired option.
6. When prompted to "Confirm wipe of all user data", select Yes -- delete all user data.
7. Select reboot system now.
door
My acer 10 tablet was stuck in black screen after disabling the boot from boot option properties. didn't start up the windows after turning it on.
door
Voeg een opmerking toe
2 Antwoorden
Filteren op:
I had a friend bring this issue to me…
turns out the brightness was just down to zero..
so pull down from the top of the tablet twice.
then about 1 and a half centimeters down just try to use your finger and catch the brightness slider and slide it to the right again and voila… working again.
Was dit antwoord nuttig?
How to fix my acer ipad black screen with grey lines
Voeg je antwoord toe
Renalie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 17
Altijd: 5,499
